| Subject |
Hold a mirror behind the exhaust pipe, after the engine is |
| Posted by |
zellamay on May 24, 2008 at 9:51 PM |
This message has been viewed 228 times. |
| In Reply To |
weird smoke problem posted by cossiemodo2000 on May 24, 2008 at 12:08 AM |
| Message |
warmed up. If water condenses onto the mirror, there is water in your exhaust, which means that you have a bad head gasket, or turbo seal leak. If so, you can have any auto shop test the head gasket, by checking for exhaust gases in the radiator, for about $25 . This will detect a bad head gasket before a compression test will, and is much cheaper.
| Follow Ups |
Post a Followup |
